DISABLING DRL's
Set the parking brake and they should go out. If they do, locate the switch and figure out how to wire a switch into the line to disable your DRLs.
When that car doesn't see you and pulls out in front of you hang on, because you're in for a ride!
remove the drl fuse
Why do so many people want to disable their DRL's?? :cheers: You don't even know that they're on when you're driving...
My thought exactly. I used to set the parking brake when I was a PI to turn them off when it was cold or raining and I was running the truck. If you touch it lightly, it will not hurt anything to drive that way.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
