FIRE IN THE HOLE
There's a fire in there alright, and its thirsty.  My odometer is stuck so I don't know exact mileage but it was less than 10 going to Denver at 75.  That 350 might have 5 or 600 miles on it is all, I hope it gets a little better the more its broken in.  My old motor used to give me 13-14 on road trips like that.  Hate to have to play the sign "Will Work for Gas",  haha.  Still gotta love it.
Mark, put 125,000 miles on 85 GMC 350ci, 4 speed, with 3:73 greas best gas mileage was 11.6 and worst was 10.0 loaded or empty it made no difference.  Up hill or down, into the wind or with a tail wind.  The best part of it was the best and worst were seperated by two other tanks of gas on a 3500 mile trip.  I would not hold my breath about it getting much better.  Sorry!!
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
