GLOW NEEDLES
Product review...just installed a white face gauge cluster and added, the glo needle kit to it....got say it looks awesome , and installation was very simple . for those of you that like gadgets, and something different , I would recommend this mod. you can get the glow kit in red, orange, green blue and purple, I got the red..... :thumbs: Rob
