Key sticking in ignition...
Need a bit of help here guys. The key won't come out of the ignition sometimes after turning the engine off. It stops about 1/8 from the OFF position. We have to jack with it for a while to get it to work.
Has anyone else experienced this or had it repaired? It's doing it frequently enough that we need to get it fixed. I called my shop, but he didn't indicate it was something common or that he knew of, just advised they could check it out.
I bet it's something simple and I would like to fix it myself if I can. I already tried lubing with a bit of silicone spray, but that didn't help.
I'm so bummed, seems like everytime I turn around I'm throwing cash at my vehicles lately. :chevy:
Roland
*excuse my poor spelling on the title...I tried to edit it, but can't.
Guys I figured this out last night!
I ended up pulling the little plug/cover off the bottom of the column and pushing the release button. It worked and the key released like normal. All this got me thinking...what and why is this switch not releasing normally? I wanted to see more. Without pulling the steering wheel I removed the two screws from the bottom column cover and popped it down to where I could see inside the column okay with a flash light. *Note, you won't be able to remove the bottom cover without removing the wheel or the knee bolster.*
This allowed me to see the release mechanism which is nothing more than a solenoid. This solenoid is activated when you press the thumb button on the shifter. It locks the key in place and unlocks it in park. I noticed it only working sometimes when pressing the button. I wiggled the wires going to the switch and kept testing. After that I could NOT get it to freeze up again which was great! It almost seemed like the button was just hanging up. At any rate I must have tested it 100 times and it still worked flawlessly. I went ahead and sprayed a dab of silicone spray onto the button of the end of the solenoid hoping if it was just a lubrication issue this would keep it working smoothly. *Note if you are testing this with the key all the way forward in the ON position you will have to press the brake before the shift lever button sends current to the soleniod.*
So if you are putting your truck into park the instant you release the shift thumb button you should hear a click from the column. If not, they soleniod is not releasing.
This all makes sense because why else would Chevy put access to a button on the bottom of the column to release the key? Answer: Just in case you try to start your truck with a dead battery. If the battery is dead the soleniod will not release.
At any rate I'm thrilled with my progress and looks like the shop can eat my shorts!
Hope this helps those out with the same trouble. Ask questions if you have any.
Roland
Roland
Thank You for posting this. I had this happen when my battery went dead in my driveway and got my key back when I hooked up a charger to the battery, but I didn't realize the ramifications...if my battery goes dead away from home, I may not be able to remove my keys... including my house key... from the car if I had to leave it there. I will be examining my column this afternoon.
Further justification to keep a set of cables there. Still debating my tool box.
Does anybody else keep a toolbox in their vehicle? If so, where?
I'm so bummed, seems like everytime I turn around I'm throwing cash at my vehicles lately.  :eek:
Roland
Stop turning around then :eek:
I'll get that for ya' :crackup:
Glad you got it figured out :crackup:
OK, I checked mine out and discovered...I've got no plug to pull off to push the button!
We are talking about a space beneath the ignition switch, correct? I remember seeing them on a '96 Yukon I drove for several years, but my '02 Envoy doesn't have it that I saw after a fairly quick glance.
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
