R&D Products
bonrea
R&D Head Light Controller
R&D Auto Door Unlock
R&D Fog Light Controller
R&D Head Light Override
What happened to the Website where these priducts were sold? If the Website no longer exists where can we get these products?
Anyone?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
