Another Newbie
Marineox
Hi, I just registered on this site and I don't even know if I'm sending this message right...LOL. I'm picking up my first truck ever on March 11th. Its a 2005 Chevy Silverado Z71 Crew Cab. I'm thinking of lifting it, but I don't know what's good out there. My buddy recommended an RCD 6" lift. Does anyone have any thoughts or suggestions?
Welcome :D And don't worry you'll get lots of advice on a lift kit,But if you don't get any advice here post your question in the "Technical" forum under "4x4 Suspension" you might get more anwsers.
I have heard alot of good things about RCD kits,I like the fact that they come with Bilstein shocks :cool: some of the best shocks around in my opinion.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
