New guy from Missouri,...
lolife99
Hello. First post. I normally hang out at www.67-72chevytrucks.com. Someone posted a link to this site,... so I thought I would check it out. My wife drives an Avalanche, I have a '71 2wd blazer, and a '71 swb project truck. I recently bought an '03 Silverado 4x4 rcsb. First nice 4x4 I have ever owned. Normally into lowered trucks and '67-'72 trucks. Cool site. Any other Missouri members?
Welcome,It sounds like you have some rides,post some pics. :cool:
  • 3 months later...
hey i live in missouri. i live on whiteman afb down by warrensburg about 45 min from KC. i like it it's nice. i have a 2001 silverado 1500 z71/4x4 i got it january...i'm in guam right now but i'll be back around sep. 1
kevin :seeya:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
