Funny Commercial- Hootie!
General Lee 01
Has anybody else seen that Burger King "Tender Crisp Bacon Cheddar Ranch" commercial where Darius Rucker (AKA- lead singer of Hootie and the Blowfish) is dressed in a purple country-western outfit and is singing in country (or trying to).
I've seen it about 10 times and it still gets a laugh out of me the 10th time.
:withstupid::cheers:
Haha, I'll have to keep my eyes out for that. Did you know that they actually broke up at one point after all their success? They're supposedly back together again now though. I like that commercial with MC Hammer and the foreclosed sign and all that was on during the Super Bowl
I have seen it. I thought it was great. I get a good laugh out of it. Did you happen to see the commercial during the 500 where DJ and Micheal Waltrip were selling auto parts as clothing, kinda like a home shopping network type thing. That one was hilarious.
William
William
Yea, that was a good one! Gotta keep my eyes open for that Hootie one too :(
Of the ones from the 500. I liked the Domino's Pizza "Mr. NASCAR" commercial. But I also enjoyed the UPS commercial where Dale Jarrett finally agrees to "Race the truck"
:seeya: I have a TIVO, so I rarely watch the commercials. But as I was fast forwarding through them Carson Daily's rig was what caught my eye. I will rewind just to watch that commercial any time I see it on now though because it's so @#%# funny.
Best commerical is for a lending company. The white cat is in the kitchen with a guy cooking spagetti for his girlfriend. The cat spills the sauce, falls in it, then the guy picks up the cat, covered in sauce with a huge kitchen knife in hit other hand.
Enter the girlfriend!
"Don't judge someone too quickly"
Go here to see the cat commercial (as well as other funny ones):
http://www.ameriquest.com
Scroll down to the bottom. My favorite is the one with the guy talking on the cell phone when he goes into the convenience store.
Scott
