Best Site to Host Pics
putfile.com - no ads, no logging in, no nuthin'. Just go to www.putfile.com and you'll be greeted with an input box and a "browse" button. Click the browse button to browser your computer for the image (or movie, song, whatever) you want to share, then click upload.
Once you've done this, you'll see the link to the file and to the right of it will be three icons. If you click on the one that has MSN messenger type of icon (two heads, one in front of the other), it will copy the exact text into your clipboard needed to paste right here in the forum to display the photo. Hopefully, you know how to paste text from your clipboard. :cheers:
putfile.com is no good for having an online album, because it doesn't work that way, but for putting images into posts in forums, it's the best. And it is probably a bit easier than I made it out to be.
Hi again...these red x's are really p@#$%^g me off...I know how to post, build computers and install computer parts, I even made a nice avatar with illustrator...but there is a setting I do not have right here to post properly....any suggestions? ALl I get are red x's with stuff I try to post...but I can see all of your pics...what is up with that? :thumbs::sigh::cheers:
If you have the pictures hosted on one of the sites mentioned. All you do is copy the url that the host gives you for the picture location. Then when you reply or post here, click on the IMG button that is right above the box you type in. Then paste the url from your picture and hit enter. If you are still getting red Xs, it might be because your file is too big. Some forums limit the size, I would have to look again to see if this site does, but that might be your problem as well. I use photobucket.com like one of the other posters and it is pretty good. You can make the pictures smaller right from their site so it is even easier to post them here.
Good luck. :cheers:
Good luck. :cheers:
Thanks, I think I am copying the url correctly, but all it does is give me a red x...it is strange, I resized to 10K...still a red x. It is a setting on my IE that is doing this I think but I do not know what to click on or of to get it to stop...any suggestions? Thanks, :eek::thumbs::sigh:
I sent you a PM with another idea.  Let me know. :cheers:
:eek: I am a boob...I was not saving it in the right file type...for some reason Illustrator generated jpg files are not compatable with the hosts...so I used the save for web feature which generates a gif...POW, no problem. Thanks for all your help...I now have a new avatar and my truck is now posted in my sig. Albeit low res. pictures from my phone...when my wife gets back from D-world I will take some high quality pics...but not too bad for a cell phone? Thanks again, later, :D:thumbs::sigh:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
