Center Console
Mighty HD
Could you guys post pics of your center console's in the 03-05's?
I'm debating if I should ditch the jump seat and put a full console in. I'm not sure if I'd miss the room on the floorboard or like the console.
Help me decide in 2005.
Mine's just like his, 'cept without all that nice leather around it. :D
As far as whether you'll like it or not, I sometimes wonder the same thing. I really like the console 99% of the time, mainly because it's only myself, my wife, and my two children riding in the truck. But if there ever comes a time that I need to get 2 more in the truck (say.. if I visit my parents and decide to go somewhere all together), that center jump seat sure seems like it might be handy.
Which reminds me, is it possible to keep the Captain's chairs and have the jump seat? (LOVE the Captain's chairs :D)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
