Factory Radio Cooling Fan?
Does anyone know if the factory radio has a cooling fan? If I have been listening to it for a long time, or if I have had it tunred up for a while, I hear what sounds like a fan come one and cycle off. Unfortunately, I think the bearings are going bad on the fan, cause it is really noisy. I may have to go get it checked out while under warranty...
That is what I figured. Mine is definitely going bad. It is making a ton of noise. And when I pulled it tonight to look for dust, I saw that it was replaced under warranty to the first owner with a factory remanufactured unit. Oh well, looks like they can replace another one...
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
