Plastic trim on door and bed...
Hey guys,
I'm wondering if anyone knows how that plastic trim on the door panels, cab, and front of bed are attached and if it's something that can be removed. The reason I ask is because I'm interested in getting Line-X on my rock panels and with the placement of that trim, it might look weird or be tough for them to work around. So I'm curious as to how it is attached; whether it's just glue or actually attached through the metal. If anyone has seen this let me know. Thanks!
attached with two strips of double sided tape. If you are going to line-x the bottom I would have them do just below the trim if you want to keep the trim on there.
Take a heat gun or hair dryer and get them warm, then you can peel them off rather eazy without the possibility of pealing the paint or leaving the sticky stuff on the paint. They are on there with 3M double sided foam tape
The trim should stick to the line-x, there is a guy that lives by me that has an OBS that has the line-x on the rockers and his trim is on top of the line-x. His truck is red with the black line-x on bottom. Looks real good. I would ask him if he did anything special to keep the trim on, such as anything other than just the regular 3M tape, but he bought the truck like that and I'm sure he has no idea.
I also am going to be doing this soon, so it better f***** stick!!!!! Have a good one guys. :flag::fume:
Heat Gun. Keep a good distance though. Man, that is a beautiful black truck. I think I would put up with a few rock chips. My buddy did the linex rocker panels and it looked good until the first winter here. After all of the road salt, sand, and grime it looked faded and dry. His was also black. It looked like two tone black and grey the next spring. He took it in and had them spray black back over it with the clearcoat. I seemed to hold up real good against rock chips. I guess the paint on top of the liner created some insulation and kept the paint from chiping off of it. A little reduntant, but you could try that route, even if it did chip you have the liner underneath, instead of bare metal. I have tried the factory splash guards to prevent chipping and they only protect a small area. I wish there was an invisible, hard, enamel that you could have applied to prevent chips. Oh well, good luck.
There is a transparent 3M adhesive backed film available (sort of like the invisible bra stuff, might even be the exact same material) through places like JC Whitney. It comes in rolls. I bought a 12" wide x 10ft long or so roll of it and cut pieces to protect the leading edges of the rear wheel wells on the 2003 Trailblazer (back door, mainly). That area was the most prone to being sand / rock / salt blasted by debris from the front tires even with mudflaps. Unless you stand right on top of it you can't tell the film is there and it DOES a good job of protecting the paint from chips.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
