steering wheel mounted audio controls
like tom said, go to my site for some good install pics.  I've got the kit, very nice and the instructions were great.  The install took me about 3-4 hours w/ taking lots of pictures.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
