attn mervz
Mervz is from New Hampshire (I don't know if he's an Indians fan!!!)
I'm closer than that to you...  I live right over the PA/OH border in Grove City.
i got headers, into a Y pipe i made w/ the flowmaster dual 2.5 into single 3 collector, and the summit single 3 in dual 3 out exhaust from there.  no catalytic converter, still pass the sniffer test.
I'm a die hard Indians fan. I lived in Ohio untill i was 7, and my parents still own lake front property on Lake Erie on Ohio. All my relitives live in Ohio, so we visit there often!
Shanners is right, i now live in New Hampshire.
umm....oh....sure...thats what I thought .:confused:...sometimes I wonder why I read these posts.  I have absolutely NO BUSINESS being here.....
(Edited by NewbieZ71 at 10:48 pm on June 11, 2001)
