Proper breathing technique
orbee
I just started a new hobby ( running ) can anyone tell me the proper breathing technique for running . I run a mile a day, 4 laps around the local school track. Thank you .
Interesting link there. I like to try starting out through my nose, but as I got I find myself having to use my mouth only and eventually doing the huff and puff, might have to try his suggestions
Just an update, I tried the nose/mouth style and it worked for my mile. The 5 th extra lap
I needed the mouth then mouth . Gotta get used to it i assume. :rolleyes:
