A new problem
doverarjim
Hey guys this one has me stumped. It has been raining here today and this mornining I drove my truck down the drive way, it is dirt most of the time but today it is muddy. I got back and parked it walked to the house and as I went in the door I saw smoke(steam???) coming from the rear of the truck. I then noticed that the parking lights were turned on? I had not left the lights turned on when I got out of the truck so I checked the switch which I had not touched was in the same position, but the door chime was going off. I started the truck and shut it off and the lights went out. About 2 hours later my son left and he yelled at me that the lights were on in my truck, once again the parking lights were on!!!! Did the same thing turned truck on shut it off and the lights went out, now the third time the lights were on I went to start the truck and the battery is dead!! Help any ideas???? :thumbs:
personally the only time i had smoke come from my truck was when i went mudding and drenched my battery with wattar. it didnt die on me tell about 5 miles down the freeway going back. so id say check ure battery to make sure . also i know that there are wiring under the trucks check to ssee if any are damaged or anything.
Hey guys this one has me stumped.  It has been raining here today and this mornining I drove my truck down the drive way, it is dirt most of the time but today it is muddy.  I got back and parked it walked to the house and as I went in the door I saw smoke(steam???) coming from the rear of the truck.  I then noticed that the parking lights were turned on?  I had not left the lights turned on when I got out of the truck so I checked the switch which I had not touched was in the same position, but the door chime was going off.  I started the truck and shut it off and the lights went out.  About 2 hours later my son left and he yelled at me that the lights were on in my truck,  once again the parking lights were on!!!!  Did the same thing turned truck on shut it off and the lights went out, now the third time the lights were on I went to start the truck and the battery is dead!!  Help any ideas???? :cheers:
Do you have the tow package? I had a problem with water/corrosion bridging the hot terminal with the lights terminal of the trailer connector. It caused the lights to be on all the time.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
