Replaced the Blazer...
General Lee 01
I bought myself a new rig to replace the Blazer, all I have to say is look at my sig. :thumbs:
I'm hoping it won't last too long (But I am hoping it lasts longer than the Blazer did).
Pics to come (If interested)
you have replaced the blue ovals by now rights? some four wheeler brand sticker fits right over, a lot of people around here do it.
    • *Your
