New guy here
GMISwahili
Hey everyone. I drifted on over here as a way to fulfill my GM truck addiction. I'm a reg over at www.gminsidenews.com and a staff member. I've become really interested in trucks as of late and figured this would be the place to be. Just wanted to test out my avatar, signature, and say hello. Going to do my best to search through your archives so I don't drive you all nuts posting questions that you've seen time and time again. I'll be here occasionally. Nice site and forum!!!
You do know about the initiation right?
Yeah, get used to saying, "Thank you sir, may I have another?"
Seriously, welcome to the site from Wingnut, and now me: the only two people who seem to post to this board between 2:30 and 4:30 am
:uhoh:
Just searching through the archives I've found a lot out about lowering a truck, but I'll have to keep searching to find some pictures. You have a HUGE forum for people's trucks and I don't have time to go through every single one, lol.
Initiation eh? ;) Lay it on me. :cheers:
It involves a buffalo wig, a toga, and a 9 iron. You have to gyrate like Elvis on meth, doing a Teenwolf like roof-surfing job on your truck, while doing a rendition of "I Believe in Miracles" in D minor.
Initiation eh? ;) Lay it on me. :jester:
:cheers:
    • *Your
