Lifter noise at startup
Hi, I have a 96 Chevy Express Van with the 5.0 l Vortec engine and I get alot of lifter noise during cold startup. It's pretty loud and lasts until the engine fully warms up. My oil press shows good (use Castrol 5w-30) and I put a half-quart of Risone in to no avail. Van runs good, passes emissions, 74k miles only
Other Vortec owners have this situation? Remedies?
thanks guys
thanks guys
Switching to Mobil 1 quieted things down at startup for me. Also a good Top Engine clean helped also but more for knock.
Use a good quality oil filter such as AC DELCO & PURELATOR
these are 2 brands that are known to have superior ANTI DRAIN BACK VALVES
I second the Mobil 1 (SYnthetic oil) for reduced lifter noise on start-up. I just switched from Castrol GTX (dino) to Mobil 1 EP and the real difference i can tell so far is the reduce lifter noise on cold start up
