Idle Speed 99 Tahoe
What is the idle spec for a 5.7L Vortec 99 Tahoe?
I get just below 600rpm in park and about 500 in drive when warm. This creates a bit of an idle "shudder".
What is the procedure for upping the idle a bit?
Thanks for any help. Still waiting on my manual.
Jason
Your idle sounds fine, but it may need a tune up if you are shuddering at idle.  You are better off finding the cause of the shudder than putting a band-aid on it.
I've done quite a tune up already. So far:
Plugs, wires, cap, rotor, air filter, fuel filter, cleaned throttle body and IAC passages.
Not sure what to do next...
Thanks
