Changing the G-80 fluid inthe Avalanche
When should I change the fluid for the locking differential in my Avalanche, synethetic or dino?  I read somewhere in the forum to change oil at 3,000.
I wouldn't worry about it until 40-50k, and even then I would only check it. These people that go around changing diff fluid every 10k are wasting money. My 2000 has 35k and I haven't even looked at it. GM syncthic fluids are designed to last 100k, that's what I hear from a freind thats a GM tech
Rear diff fluid change after 500 miles of towing.
Do you have the locking rear end?
I know the silverados all take the synthetic fluid.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
