Trailer Tires
willieboy
It is time for new tires on the popup camping trailer. Most vehicle radials won't work for RV trailers because they don't have the appropriate weight rating. So, I am back to special trailer(ST) tires. I am looking for either 5.30 x 12 bias ply, or ST145/R12 in radials.
Current Contenders:
Carlisle Bias Ply - I had one trailer with these, and they lasted quite a while, but started splitting laterally along the tread. American and Asian Sourced
Duro Bias ply - My current trailer has these. Same symptoms as the Carlisles. Used to be American sourced, but now Asian
Towmaster Bias ply - Had these on a trailer for a short time, but sold the trailer shortly afterward. Seemed good, but have no idea on longevity or durability. Completely Asian sourced
Carlisle Radial - No experience. The few that I know that have them seem to think they are decent. Origin unknown
Transmaster Radial - No experience. I don't know anybody with these. Origin unknown.
So, if you guys can give me your opinion, that would be great.
I went through the same situation last year with tires for my boat trailer. Did a lot of Consumer Reports type research to figure out what I wanted.
After all that, wound up going with Carlisle bias ply, but only because that's what the local tire shop stocked. Don't think it was a bad decision because the worn out (dry rotted sidewalls) tires I was replacing were Carlisle bias ply and they lasted 9 years.
Good luck. Think you'll find a lot of brand loyalty that really doesn't help you make a logical decision.
