1500HD and 2500HD
I searched hell and highwater looking for a thread on this I know it has had to been asked a million times......
Does the 1500HD use the green keys or the ford keys?
Thanks Guys...........This place rocks
:devil:
:devil:
The 1500HD uses the Purple Keys(Part#15045171) and the GK torsion Bars(8615 ft.lbs of Torque.)(Part #15528963-Left and #15528964-Right). The 2500HD and 3500 use the purple keys as well but they use the GL bars(8782 ft lbs of torque). :devil::P:D:eek:
So that would mean the Green keys would lift the same as in the 2500 becuase only difference is the torsion bars :devil:
Well that answers my question then I think :devil:
Thanks Jacqson
:P
So that would mean the Green keys would lift the same as in the 2500 becuase only difference is the torsion bars  :P
Thanks Jacqson
:D
If your looking to just level out your truck then the stock purple keys will work fine, if you want to get more lift in the front then use the Green keys. As you can see there is not much difference between the GK and the GL bars.I just noticed we're almost neighbours.:devil:
Thanks guys!
Lance (Jacqson), our Tacoma neighbour was asking (at least partly) on my behalf as he has a set of green keys gathering dust. I was going to call you to get your opinion on leveling out my truck but I lost your phone number. We weren't sure if his keys would be what I need for my 1500HD but what you are telling me is that all I need to do is crank the stock bars and I should be OK. I will follow up with you in a PM soon.
Josh, thanks for the phone call yesterday and for following up. If I get a little more agressive on the lift, I will get back to you.
Lance, you have bars. Are they still available? Maybe you and Josh (Wile1) should package your 4-sale items if someone would be needing both???
Cheers guys, :devil:
Jim...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
