The salvage yard gods.....
It is not too unusual to find a engine sitting in a bone yard with a stuck ring or two on a few cylinders but they usually break free after you run it a bit and are fine after that. When I got a engine for my sons Toyota last year it have little compression on one cylinder but after running for a while it was even on all 4 and ran great and still does 20K later and uses no oil to speak of either.
Yea. But I was dumb enough to take the other motor home without a comp check. I actually heard this one run. Made me feel alot better this time go round.
