Heated Seat Element Replacement?
I posted about this sometime ago but never acted on fixing it. GM dealer said it is my element that needs replacing not the switch. Problem is they claim it will cost $1030 for an aftermarket (non-GM) element. Somebody out there must know of better prices to do this job. I just need the element I can replace it myself.
HELP!!!!
$1000. Whoa. I could probably send you an element for that vehicle. I have a couple of them for a 99'. Problem is I don't know if the elements changed from 98-99. You would have to measure some things and feedback the data to me before I could know if it will work.
I am wondering if the dealer diagnosed it correctly. Did they say of it was the cushion or back element that went bad? Is your system single-mode or dual-mode? Meaning can you turn just the back element on? Does your bolsters heat up? I need to know what seat (driver/passenger) and I can tell you exactly what terminals to check for the process below..
Measure the resistance of the heater pads connected together. I'm pretty sure they are carbon fiber elements. The only way to do this is measure the voltage going to the seat during operation and then measure the current through the system during operation. You cannot measure the resistance in a traditional sense with carbon fiber pads (i.e. directly using an ohmmeter at the connector). Sorry...gotta do it the hard way and back calculate the resistance. Use V=IR.
You might also have a problem with the trim. I am not sure, but I know some of those years used hog-rings in the trenches. You will need a hog-ring tool.
BTW - I work for the seat supplier and have many "seat electrical" items laying around. Just so you know, this is legit...if everything works out we can talk about shipping/compensation/etc...I'll help if I can.
Well they said it is so expensive cause they claim you can't just buy the element for this truck anymore you have to buy the whole seat cushion/element combined, plus they quoted the labor as well in that price.
Anyways I think '99 should be the same. Its a single mode and its the drivers side. Bolsters do not heat up as well. Stealership said both elements were bad, thought they were separate and usually don't both go at once.
Yukon04 any info you can give to testthings would be great. Just post here or PM me. I really appreciate it. I also need a lower seat cover in blue if you have one of those kicking around.
What a rip off. They just do not want to sell just the element as there is more profit in the whole seat whether it is a a GM or dealer directive. There is no excuse for that at all.
Yeah its just like the d**n fuel pump/sending unit module. Why can't I just buy them separately d**n it!!!! All in the name of making more money I would think.
There must be an aftermarket company making replacement heating elements for these seats though. :thumbs:
I think the dealer is telling the truth. I called the heated seat supplier and they no longer producing those particular pads. The pad itself is sewn into the seat trim. Hence the riduculous cost. I also talked it over with engineering and we believe (98 was a long time ago) that the heater mat actually has the plus pad built into it, so servicing your system with what is know as "peel & stick" would also be detrimental to performance. In that case, you could remove the trim, cut the pigtail off the heater pad, leave it there and place an adhesive type of heater pad directly on the foam. This would not work because you'd have so much material between you and the heater pad, that heat performance would suck.
Anyway, just to check if the dealer is diagnosing your problem correctly try this:
You mentioned that the system is single mode, meaning that you can only operate the entire seat, cushion & back together. This is relatively simple to test. Look under your seat and locate the connection to the heater pad. There should be 4-way connector with 4 wires in it, 2 small gauge (22Ga) and 2 larger wires (approximately 18Ga). Probe the two 18ga wires with an ohmmeter and measure the resistance. Should be around 4-8 ohms...even if it is slightly off, continuity is the important part. If no continuity, then the resistance wire in one of the heater pads is broken.
To locate which heater pad (cushion or back) is broken, you need to check the back pad separately. The cushion and back pads connect via a 2-way connection. Find this one, should lead up near the back of the seat. Check resistance, shoudl be around 4 ohms, but again just continuity is the important part.
Once the defective pad is located, remove the trim on the seat. This may not be an easy task as it may be hogringed in the trenches. A hogring tool is necessary and you may as well go to a trim shop for assistance. Unless you have one :thumbs: . You can actually repair the resistance wire by soldering it back together and re-enforcing it with some heat shrink or equivalent. This obviously requires you to CAREFULLY cut into the plus pad of the trim and remove the heater pad. Do not ruin the plus pad. Make a slice like a capital "I" so that you can duct tape it back together. Find the break in the heater wire, copper/nickel type material and solder it back together.
This all assumes that your heater module is still good...but that's another story. Sorry for the book I wrote, but I feel bad. The pads I said may work for you will not. The 99's changed significantly. Good luck :cheers: and let me know if you have questions...
Sam
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
