One Stone
Scyry
An Apache Indian with One Testicle.
There once was an Apache Indian whose given name was "Onestone". So named because he had only one testicle. He hated that name and asked everyone not to call him Onestone.
After years and years of torment, Onestone finally cracked and said, "If anyone calls me Onestone again I will kill them!" The word got around and nobody called him that any more.
Then one day a young woman named Blue Bird forgot and said, "Good morning, Onestone." He jumped up, grabbed her and took her deep into the forest where he made love to her all day and all night. He made love to her all the next day, until Blue Bird died from exhaustion.
The word got around that Onestone meant what he promised he would do. Years went by and no one dared call him by his given name until a woman named Yellow Bird returned to the village after being away for many years.
Yellow Bird, who was Blue Bird's cousin, was overjoyed when she saw Onestone She hugged him and said, "Good to see you, Onestone."
Onestone grabbed her, took her deep into the forest, then he made love to her all day, made love to her all night, made love to her all the next day, made love to her all the next night, but Yellow Bird wouldn't die!
What is the moral of this story?????............................
OH, come on...take a guess! .
Think about it .
And the moral is .
You can't kill two birds with one stone!!!
Think about it .
And the moral is .
:thumbs::cheers::seeya:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
