Dip-Stick Tube Oops
Cool Zr2
I removed my headers off my truck today to do some work to them and I ended up snapping the tube off at the block, well, about 1/8th inch in.
Now, what would be a good solution to getting out the rest of the tubing in the block? Can I take a drill bit that is the same size as the hole and drill out the remainder of the tubing untill the tail (in the pan) falls out? Then use a pen magnet to get the tail out of the pan and flush the hell out of the motor with a case of oil to get the shavings out? I'm thinking of a soft bit that can cut the tin fine but won't harm the block. I have my old 305 here so I can determine the proper size to use, that dipstick tube comes out without a problem.
Its a real pain in the butt to drop the pan cuz the whole front diff has to come with it. So anything that will save me time will be awesome.
If you can, I think it'd be better to just drive the whole piece in and let it drop into the oil pan. A piece of tube laying in the bottom of the pan isn't going to hurt anything.
It's been a very long time since I removed one of those tubes. I'm thinking there's an inside section that goes in from the inside of the pan. But it's been years since I really paid any attention to that and could be wrong.
Its a one piece tube, slides in from the out side and there is a "stopper" in the pipe, so I'm guessing pushing it into the pan would be my option, my pen magnent should get it out of the pan.
Thanks!
Oh yeah, I remember those. Used to use a crows foot to install them as I recall.
I broke a dipstick tube off in an old 350. Headers...
I thought I could pull the pan and drive the tube up from the bottom. I found that the hole was smaller at the bottom end, stepped near the middle of it's length. I ended up drilling it out with the oil pan off, but it was a pain to keep the drill bit straight.
I would suggest starting with a drill bit smaller than the OD of the tube and working your way up. Maybe pump some thick grease down the hole and try to blow it back out with the shavings when you're done?
I guess if the tube extends down into the pan, you might be able to pull it on down through if you get creative with vise grips, baling wire, and a pry bar. Good luck to ya!
Try a tap the will start to cut into the pipe some from inside end but it not too large and when you get a good bite (but before you thread it in too far and possibly swell the pipe) grab the tap with a pair of vise grips and try to pull nipple out. Be carefull not to bend tap because they are a bit brittle.
OK, the tube is broke off about 1/8th of an inch into the block, now, I would rather loose a finger than to take the oil pan off of my truck.
If I determine the correct size of the hole from my 305 on my stand, and get a wood bit, it should scheer out the tin and not harm the iorn right? being that it is a soft bit? and then flush out the shavings and fish out the rest of the tube from the oil pan via the plug hole with a pen magnent?
I would not do that. I would try a tap and pull or drop pan and tap it out because if you bore it out you could damage hole, break bit and get it stuck in there and if you are sucessfull you will get a lot of scrap in pan that you will never flush properly without dropping it. A tap and pull will yeild the least amout of scrap in pan.
I'll see, but its seized in there pretty bad.
also, I don't see how drilling this out would be any different than installing a plug for the oil line on a S/C.??????
If I can't flush the shavings out, than the filter will get them right?
They have to go thru the pump to get to the filter and risk gauling the pump and filter can bypass when full or oil is cold and thick. If you cannot pull it from above, you really need to drop pan and do it from below.
Well, this is what I did.
Tried to use a coat hanger and bent a sharp 180 in the end to try and pull it out from the inside, and used a slide hammer, it didn't budge, the tube is seized in there pretty bad.
So, i took the top 5 inches of the tube and cut it off the main part, and slit the bottom 2 inches of this peice so I could give it a taper. I put a tiny bit of black rtv on it for good luck and taped it in.... well, pounded it in and its in there just as good/bad as the other tubing. So the tube is inside of the first tube...get it? Its sealed up tight and serves the same function as it did 4 days ago but shorter and betweem my #6 and #8 pipes.
Then I took the dip stick and cut it to length and put the top/stopper back on and its good to go. I just have to keep out of the deep water untill I put my lift on and replace the goobered up mess I got my self into.
I'd host a pic of it but I don't have frontpage on my new pc yet, the custom fabbing looks really good and even though its just a dip stick, it makes the engine bay less crammed than it already is.
An interesting fix that shows some well thought out ingenuity too! :thumbs:
Here is a couple pics.
And no my valve cover gaskest arn't bad, I spilled 1/2 a quart of mobil one when I changed the oil..... :thumbs:
And I also noticed that my motor mount adapter plate seems to have a bit of sag to it, my drivers side dosen't do it...... must be the weight when it torques.... Gotta get a new one i guess.
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
