Need help on brakes.
GM GIMP
I just got through replacing the brakes on my '94 S10 blazer. It's a 2wd
4.3 W engine with 126,000 mi., front disc and rear drum. I replaced pads, rotors, bearings, calipers, shoes, drums, master cyl, all the rubber hoses, wheel cylinders, spring kit, and power booster.
After the installation I adjusted the rears up to snug and began to bleed the system. I used both a vacuum pump and the old fashioned two man pump the pedal and release fluid methods. I couldn't get the pedal to come up. I swapped the master cylinder again thinking maybe I got a bad one. I even tried
cycling the antilock by stopping on a rough road. All that did was lock the front wheels; I had to unplug the antilock unit from the 12 volt source to unlock the wheels. I tried it three times with the same result each time. So I bought a used antilock unit and installed it. The unit worked without locking the wheels but I still cannot get a good pedal. The antilock light still comes on and the brake light comes on when I press the pedal and it goes almost to the floor. Is there anything else I can do or does the dealer need to take over from here? I do feel that air is still in the system but I don't know how to get it out. I've used three quarts of fluid so far. PLEASE HELP!
Sorry for the long post.
  • 3 weeks later...
OK Then, Since nobody seems to know how about this: How does the dealership service Dept. bleed a Kelsey-Hays anti-lock unit? I see two bleeders on top of the unit but when I open them nothing happens. :thumbs:
We've never bled the unit itself by those two bleeders on the anti-lock unit. I'm not really sure what they're for and I've never seen anything from GM about using those to do any sort of bleed procedure.
We have an automated bleed function built into our scanner that we use on these. Prior to having that function, we did just what you tried... taking the truck out and putting it into an anti-lock stop to activate it and try to get the air out of it. That didn't always work and I can remember fighting some of these for quite some time. The automated bleed works well to get the air of out the unit.
Other than that, most guys in the shop prefer the ol' two man method. One pumps the pedal a few times, holds it, and the other cracks the bleeders at the wheels. We also have a vacuum bleeder and a pressure bleeder, but the two man method is still the preferred method.
I will add that one of the tech's has a older Blazer that he did everything to get the pedal up after making a repair. He automated bled that thing 'til he was blue in the face, tried the vacuum bleeder and manually pumped probably two gallons of brake fluid through it. He recently left for greener pastures, but as far as I know, he never did a get a good pedal on it. I'm pretty sure he's going to have to replace the anti-lock unit on it but I don't know if he ever did.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   0 Members, 0 Anonymous, 973 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
