Allison tranny troubles anyone?
Buddy of mine is having troubles with his Allison transmission. It's a 2001 Duramax regular cab, 4x4 with probably 70k on it. He's pretty hard on the truck...pulling very heavy loads...putting lots of miles on it per year.
And by heavy loads, I'm talking 30,000 pounds! Broke the rear housing on the tranny, then got a rebuilt one...and that one went out soon after.
Anyone else having Allison tranny troubles? My 04 8.1/Allison is running well.
When you pull anything repeatidly beyonds its designed limits. Parts will fail sooner especailly if engine is boosted too. From what I have seen and read that 70 to 100K service life in hard use is about the norm for that tranny behind a diesel with some getting less. The Allison can be beefed up but if he broke the housing once not even beefing the internals is going to help much there because it is exceeding the design limits of the unit. If he pulls that much weight all the time he would do well to re gear the truck to 4.10's or so because that would decrease tranny loading and temps at any given speed while increasing pulling power too and may be just enough to greatly extend its life too. I do not care what you do to engine or tranny, 30k with 3.73's is just too much drive line torque load for that chassis on a regular basis. Even Dodge wisely offers a 4.10 option for serious towing with its basically bullet proof Cummins.
The Allison 1000 in our trucks is designed for up to 26K GCW. Your friend, plain and simple, is asking too much of the transmission. He either needs to beef it up with a good aftermarket kit (and still may have problems), or he needs to get a vehicle with the proper drivetrain to handle 30K towing weights. A medium duty truck comes to mind.
Also, in response to snoman's suggestion on rear gearing, the 3500 series GM trucks can now be optioned with 4.10 rear gears with the DMax/Allison.
Good because they were breifly offer with a 4.10 option when it was first offered before it was withdrawn and I am glad to see it is back again.
I just picked up an 04 2500HD w/ the 8.1L, Ally and it has 4:10 gears. I haven't towed anything yet but will be hooking up to the 5th wheel for the season opener at the end of the month. I can't wait! That darn camper will move now or I'll rip the hhitch off!
I think it should make a fine tow vehical with 4.10's and pull OD better even with a load.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
