Several hours at least for all that. It depends on how much dust and debris is caked onto your paint, and how detailed you are. What kind of lubricant are you using?
Mothers is good. Meguiars makes a good kit as well. I just did mine for the first time early last month...results were excellent.
I did mine after 5 years and the results were amazing. The paint is like glass. It's much easier to keep clean. I used Meguiars too.
WOW.....It was well worth it. I can't believe how much it shines. I'll post pics later. You guys are awesome.....but making me poor. So many things I wanna do with my truck now. Body lift coming this week. New tires and wheels later.
That's good to hear man. And yeah, definitely get some shots of it. I'll probably wind up doing mine again next month or so.
Wash/claybar/wash/polish/wax
Thats how I wax all my cars, but it sure is worth it. Everyone is amazed how smooth I get the finish, and my Polo Green looks awesome after Im done.
Great lookin truck :confused:
Yeah that looks pretty sharp bishop. I'll definitely need to do mine agin fairly soon, and then soon thereafter, it'll get covered in a bunch of yellow pollen again!!
Yep. I just did the clay bar thing / Meguiar's NXT liquid wax treatment on my truck this past weekend and it's already starting to get coated in pollen.
BTW, thumbs up to the guys that recommended the NXT wax- I was worried about wax residue on all my flat black plastic trim (moldings, fender flares, mirror housing, etc.). Even though I know I had to have got some wax on it the NXT doesn't leave the whitish residue. I need to clean and treat my moldings again anyway though, because the small indentation running the length of each about 1/2" from the top has a light brown coating of dust in it that I missed when I washed it.
I know what you mean about the pollen. We had literally about a 2 minute light sprinkle at most, but when I checked the truck after work, the hood was all dusty-ish. Sure enough, looked like pollen to me. I put some NXT on on Sunday, and despite the layer of pollen, she still looks great from a distance.
  • 1 month later...
:seeya:
Get Meguirer's or Mother's ONLY.
Clay Magic SUCKS.
Autozone, Hi/Lo, any decent auto parts store should have it. If you can't find it near by, it's available online.
I have a BRAND-NEW, unopened Clay Magic set..... anybody want to buy it ?? Cheap :cheers: !!!!!!!!
    • Those  headrest speakers look fun! Standard panoramic roof on the AT4X might be a deal breaker for me unless I can delete it. Maybe I should just supercharge my truck and call it a day. We'll see what I think of all the new trucks when I see them in person.
    • "Increase"?   You want to "increase" your turning radius?     What is your truck?  What kind of cab and bed do you have currently?  Is it stock?  Modified?  Lifted?
    • OP's quote is parts and labor.  Not just parts.     The # you found isn't the right one.  But besides that, the right # is the same price within a couple bucks.  $5802.01.    Now, factor in labor and fluids.  Book time is 17.1 hours for a Colorado 8 speed.  At $200/hr for a dealer average rate, its $3420 just in labor.  We are already at $9222.  Fluid and other necessary items, there's your $400-500 more.      Also.  Your "discounted" transmission.  Which is 99% likely quoted off of GM Parts Direct as that's the MSRP I found on their site.    You failed to note the $597 in shipping charges.  So we are right back almost to MSRP.  $5794.  Oh.  AND, you better have the $4000 for the core charge which you'd have to pay and get refunded, AND you gotta pay to SHIP THE CORE BACK.    So now you'd have paid MORE to buy that one online yourself, even after you get your core refunded.
    • I would like to know if I can increase my 2025 Silverado 2500 HD
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
