touch screen Lux ???
m2005
099 or 531 which of these two (2) Last Three Digits for the touch screen is for XM and 6 disk combined have spend many 100's to get this right. No more mistakes. Please help!! :driving:
THE #'S YOU LISTED ARE THOSE PART OF THE PART # ?
IF IT IS GIVE ME BOTH PARTS AND I CAN FIND OUT IF NOT THEN GIVE ME YOUR VIN AND I CAN FIND OUT WHAT PART # IS FOR THE XM RADIO WITH 6 DISK CHANGER
JUST EMAIL ME IF YOU DO NOT WANT TO POST YOU VIN #
Based on the partial numbers you provided, I believe you're talking about:
15230099
10377531
The former p/n is I believe a replacement (substitute?) for 10377531; both are TNR touchscreen nav units meant to work in a factory-installed Y91 (Bose lux amp) GM truck/SUV (or a lux amp purchased after the fact, along w/ any wiring modifications that may need to be done if adding the lux amp to a vehicle that didn't originally come with one). Both can control the factory XM module (assuming you have it in your truck to begin with) and the slave 6-CD changer, assuming that either nav unit didn't get reprogrammed (probably not but it might be possible).
I know 0099 will work for sure because I swapped out the factory-installed INR nav radio from my '04 DXL w/ a 0099 TNR unit, and I can still access factory XM. In all honesty though--I don't know 100% if it will work w/ the factory slave 6-CD changer, only because I replaced it with a Pioneer AVH-P6500DVD head unit...but I have no reason to believe that it (slave changer) won't work w/ a 0099. :driving:
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
