'93 S-15 Jimmy Headlamp problem
The Pivot & (Pulse) Switch ASM no long clicks when you pull it towards you to turn on the brights and both headlights will not work. I spoke to a couple of folks at local garages and also have been going through my service manual. I have gotten a much better picture of the physical layout of system. After taking off the panels underneath my steering column, I was able to reach the Dimmer Switch Actuator Rod at the break in the cover to the steering column and turn my lights on by moving it. I am not sure if the brights are on or not, but it doesn't look like it. Then when I pull on the turn signal like I would to turn on the brights, the lights go out. I'm thinking that the connection between the Dimmer Switch Rod and the Pivot Switch ASM is broken - like a broken or missing clip. I'm not sure from the diagrams in my manual how the rod connects to the PIvot Switch.
What could be the problem: loose or disconnected Dimmer Switch Rod; bad Dimmer Switch ASM; or something else. The Dimmer Switch looks like a real bummer to get to, and I have yet to figure out how to get it out. Any help is welcome. :chevy: Looks like taking the steering column apart will not be much fun either!
Thanks!!!
Welcome to the Forum :thumbs:
This may sound like a dumb question, but are you sure that the headlights are GOOD? I would check for power at the headlight sockets first before tearing the column/dash apart.....just a thought
But if it is the switch and or the pivot and rod assembly...I would suggest that you get a repair manual and reveiw it before attempting to dis-assemble the steering column to check the linkage...if you have to get that far after you check the switch.
You should be able to gain easier access to the switch by removing the 2 nuts that hold the column to the dash, and lowering the column. This will give you a little more room to work......good luck
'93 is a ways back, but if I recall correctly, to get the dimmer switch off, you have to first remove the ignition switch. Or maybe it was the dimmer switch that had to be removed to get the ignition switch off but I seem to recall it being the other way around. :ughdance:
If you go directly to the dimmer switch and operate the plunger with your finger, does it operate smoothly and give a crisp click each time you press it? If so, the problem is probably further up the column, but the switch is the more likely problem.
If you feel a springy feel to the t-signal lever when you try to operate the dimmer, it's unlikely anything up in the column is broken. It's hard to describe how it all works up there near the lever, but if you saw it, you'd see that it either pushes the rod to operate the switch or it doesn't. The odds that it sorta works up in that area is very slim.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
