Not that anyone cares
facn8me
Our first half day on Friday's start's today. Work 4 paid for 8. What a bargin. We get 9 of them.
On a side note cheerleading camp has started. Sometimes the veiw is just amazing. :bs:
Oh and why no more truck o the month. I figure with 15k members. within 15,000 months mine would be picked :ughdance:
