03 sierra trans noise
Its an 03 sierra 1500 regular cab with a 4.8 Mostly highway miles for its 29,000 mile life.
Under a small load, either acceleration or gear in the back, the trans will make a tin can noise as it goes through the first two gears. Its not as the trans shift but as it goes through the gear. It sounds the same as a manual trans does when you're in too high of a gear and put the power down.
Going to the dealer soon but woud like to have heads up so they don't rip me off with some trans flush fix! thanks
kevin
