online diecast Posted June 20, 2005 Posted June 20, 2005 I just bought a 2002 GMC Sierra 2wd 4.3 liter long box and on gradual curves to the right i hear a noise coming from the drivers side front end like a Ting ting sound or two pcs. of tin hitting each other. Any help? Also just as i touch the breaks the same side (drivers) makes a light sqeak then goes away. It also appears the same side leans a bit lower then the drivers side when parked. Thanks in advance Brian
GM-Tech Posted June 20, 2005 Posted June 20, 2005 Can't help you on the noise. Doesn't sound familiar. Brakes squeak sometimes. Chevy trucks are usually lower on the drivers side. Usually requires a bit of shimming of the springs.
online diecast Posted June 20, 2005 Author Posted June 20, 2005 Can't help you on the noise. Doesn't sound familiar. Brakes squeak sometimes. Chevy trucks are usually lower on the drivers side. Usually requires a bit of shimming of the springs. <{POST_SNAPBACK}> Thanks for the help, I have found out since the truck had sat for a while that rust is on the breaks and they need to be replaced and the rotors. Brian
