How do I remove my Dash? (05 Sierra)
I hardwired my radar detector (V1) over the weekend and I'd to mount the remote display somewhere. I need to pull off my dash to do so and I thought I'd check here for "how-to". I'm still having trouble with the forum's search function and apologize if this is dupalicious.
Also, where can I view (online or otherwise) or buy a service manual for my 05 Sierra? MyGMLink.com doesn't seem to offer this, but it may be that I haven't been able to register my VIN yet since I just bought this truck. I saw that GM sells some 3,000 page manual for $135, but I think this contains a little more information than I'm looking for.
Thanks. :fume:
You looking to pull the whole dash or just the bezel?
Just the bezel, I guess. I run the wire under there and have it come out somewhere around the steering column.
If you put the parking brake on, and tilt your steering wheel all the way down, then put the shift lever down to 1st gear (assuming its an automatic trans), you can carefully pull the whole bezel out to where you can run the wire in it. The bezel is only held in by a bunch of little clips. You can apply a little pressure when pulling it out, just don't get too carried away. Then when your finished, just push it back in and it should snap right in. Hope this helps. As far as the Helm's manual its going to cost bout 150 bucks and is probably what the other guy posting is refering to. I noticed Haynes and Chilton seem to be slow on catching up on the newer models. (Yes, I know they aren't that great for the gear heads, but for people like me who don't know much, they work pretty well and cost a lot less.) Good luck.
Thanks firefighteremt! I was hoping it was something easy like this, but I didn't want to mess around with it too much and break something. I'll try it when I get home! :cheers::fume:
On my 01 you just use your fingernails to get under the trim around the IP then pull - it makes a scary snapping/cracking noise but the trim comes right off and goes right back on ... I've done this many times with no problems whatsoever. That's what I did to run my V1 remote's wire to the steering column - I then mounted the remote with velcro right on top of the column.
Thanks everyone. I was able to snap my dash off as easily as everyone stated. My remote display is mounted and lookin' good! :fume:
    HWN808
    HWN808
  • Who's Online   4 Members, 1 Anonymous, 721 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
