I just bought a 2001 tahoe 5.3 vortec . about 15 seconds after shutting off the motor I hear a loud pong noise coming from the vehicle . it sounds kind of like hitting the side of a metal drum filled with water . any idea what this is and should I be worried. thanks
It is your muffler. I had my dealer replace mine, from the head pipes to the tailpipe, the new muffler sounded like someone throwing rocks at a tin drum as it cooled down. That seemed to last about 5000 miles then it stopped.
The next time I brought my truck in for service, my service advisor showed me a technical service bulletin (TSB) stating that there is a problem with the mufflers, but there is not a fix at this time - DO NOT REPLACE THE EXHUAST SYSTEM!
I changed my muffler to a FloPro 2503 and love the low burble and no sound at cruise.
Good luck!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
