First Oil Change
chevy4x4trucks
Message center came on to "CHANGE ENGINE OIL" @ 3128 miles. Got to the dealer and they changed it @ 3150 miles.
Went to the dealer because they offered two free oil changes at time of purchase. They used Valvoline All-Climate (I think it is the cheap stuff).
No, there was no popcorn, movie or receptionist lovely. Free coffee was available and there was a TV but not cable TV. They finished in an hour (first come first serve oil change policy) and no, they didn't wash the truck either.
One freebie down...one to go.
My light hasn't come on yet for the first time.  The truck has about 2750 miles and is almost 7 months old.
I will be taking mine to the dealer also.  I get the first change for free plus I have a couple of things for them to look at.
My second change will also be at the dealer too...  and so on and so on...
The reason I do this is it is 30 minutes or less, and everything is documented so I have nothing to prove if I were to have some sort of failure.  All the work that has been performed is in their computer.
Is anyone using synthetic oils in their engine?   :exclaim: I would think there would be more protection with synthetic versus your normal conventional oils.  Just my thoughts
Duty, Honor, Country
i am running and have been for about 15K miles.  Mobil 1 5w-30
RyanbabZ71....I hope we are not the only one's doing this.  I have heard nothing but good things about Mobil 1 (M1).
Are you also going with the AC Delco Gold Oil Filter....it is supposed to be the best as far as filtering your oil.
Take care.
From what I've been told synthetics are really good, but be careful.  If you ever HAVE to change oil for some reason and you switch to a nonsynthetic (or sometimes just a different one) it can really mess things up.  Not sure if this is still true, but it used to be.  I use Havoline, because it is what was beng used in my Blazer already when I bought it, so I stuck with the same thing to be safe.
HUH?  2750 Miles?  7 MONTHS OLD?  What do you use it for?  Driveway patrol?
i am running the regular AC delco PF59's.  Got a bunch at walmart for 50 cents each.  I heard they arent stocking them anymore so if i have to buy elsewhere i may go to the gold filter (i have 4 or 5 left though so i am good for a yr)
OH yeah, I remember that thread a while back!...you still living off those filters Ryan?  Didnt Walmart misprice them or something and you bought a bunch?
No i bought 2 they rang up 50 cents each.  Went out to my truck walked back in and bought the rest on the shelf.  Total was 12 or 14 all together.  I asked if they were marked wrong after i bought em and she said nope
I wish I could find them that cheap.  Our Wal-mart still carrys AC-Delco for now, but they don't have the size I need anymore.  So I've been using Fram, and occassionally WIX.  But I believe I bought my last WIX.
When I changed my oil last week, I opened the protective flap covering my oil filter and there was oil everywhere.  I had never had a drop in pressure and there were never any oil spots so I never knew this was going on.  After I got the filter off I looked at it and it has a split in it.  That scared me a little.  I already had another WIX filter, so I used it, but I've been checking it alot.  I think I'm gonna go with Fram from now on.  I only used the WIX when I was too lazy to go to Wal-Mart anyway, and just ran down to the nearest parts store.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 273 Guests (See full list)
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
