4x4, traction control, switch cubby
willieboy
I have neither the traction control or 4x4. Instead there is a useless little cubby thing there. I would like to install the holder for the switches, as well as four blanks and then install my own switches for lights, etc... Could someone provide me with the part numbers for both the blanks and the switch holders?
FROM WHAT YOU ARE SAYING, YOU HACE A CUBBY ON THE LEFT SIDE OF YOUR STEERING WHEEL WHERE NORMAL ON A 4X4 TRUCK YOU WOULD HAVE 1-1/2 BY 4 INCH PLACE FOR 4X4 SWITCH
Exactly, except it is only about 1 inch wide, 4 inches tall, and maybe 1 inch deep. I want to replace it with the switch panel, but with 4 blanks and no switches.
I WILL CHECK TO SEE IF GM HAS PART # FOR IT, BUT I THING THE ONLY 2 OPIONS WERE A CUDDY OR 4X4 SWITCH, HAVE YOU SEEN ONE THAT HAS A FILLER PANEL THERE
No, I have not, but 4x4's without traction assist has at least one empty slot. Just as the 2x4's with traction assist have 3 empty slots. I was hoping that I could just get the blank. However, if it is not available, I guess it will be fabrication time.
No matter, that "cubby" is the most useless thing I have ever seen. I kind of wonder why they did not just make a flat panel for that area (which is what I actually want).
holder no. 15040483
blank no. 15734687
That is one big blank on the top and two smaller blanks on the bottom that are removeable.
holder no. 15040483
blank no. 15734687
HOW DO YOU LOAD PIC
holder no. 15040483
blank no. 15734687
HOW DO YOU LOAD PIC
your pics have to be hosted by a photo hosting site (like photobucket.com or most IPs provide free hosting space.
Once hosted, you supply the URL tag from the hosted pic to the IMG window on your post and then it will show up on here.
The pic is for the cubby where the Onstar, etc... goes. I am looking for the one on the left (drivers side) of the steering column.
Oh, for that area you only have the choice of factory switches or the cubby hole.
