can anyone help?
I have a problem with my ESC.  I am told from 85-88 it is located under the hood in a common area.  But where????
I have traced every possible harness, am I missing it and just not realizing?  Any help is appreciated.
Ahhhhh...the forum is put to the test......anybody help this guy and actually prove that we do provide some valuable info at times?
Wheres Shaners when we need him???Tom??
Back to the top of the forum!
I think,and this could be way off,that it actually ties into your Knock Sensor and feeds off of it to adjust your timing.
If this is the case,locate your Knock Sensor and trace wires until you find the plug.
I've traced every bunch of wire(s) back as far as humanly possible from the Knock sensor, still no luck.  I have even gone into the dash to see if it resides by the ECM.  Why do designers do this???
Someone knows, I'll just have to be patient  Thanks for the replies keep them coming.
LT1,
I'm sorry man but it's been a long time since I've been under the hood of a mid '80s truck.
I wonder if we moved this topic to the light-duty forum if you'd get better response.
What do you think guys?
(I'll do some checking for you though)
(Edited by Shaners at 8:10 pm on July 25, 2001)
Quote: from Shaners on 7:09 pm on July 25, 2001
LT1,
Consider it done.
Your talking about Electronic Spark Control, right?
If so, like Shaners said it's been a long time since I've messed arounf with a mid 80's truck.  I think on the '88's and it was located under the hood, on the passenger side of the intake manifold.  I think!?  Don't know if that will help what so ever.  LOL   Good luck, if I come across any info, I'll be sure to let you know.
LT1,
Found that ESC module yet?  I believe it's on the right hand side of the block by the throttle body, looks like a "square" and should have a 4 wire harness that is easy to unplug.  Should only have a couple of mounting screws.  Be sure to disconnect the neg. battery cable first.
HTH,
BIG BLUE
Success, this is probably one of the best forums for assistance.  Thanks to all who participated.
