torsion bars
Just got my 05 Z71 Suburban and I don't like the frontend low. I have cranked up the torsion bars to equal out the front end and it still is to low. Has anybody changed out the bars, if so what did you put back in their place. The pork chop needs more room to travel.
Can anbody help.
Can anbody help.
There is no need to change out the bars.If you can't level out your truck using the stock torsion bar keys that are on your vehicle then use a set of Ford Keys(P/N-XL3Z5B328CA). These keys are more indexed than your stock keys and will give your front end more lift. You can get them from your local Ford Dealer. Just so you are aware, the more you crank up your front end , the firmer the ride will be. If you crank it too high then you will start to get premature wear on your front end components. If you just crank to level out the truck you should be OK. Don't forget to get a wheel alignment after you lift the front end. :crackup:
