how fast you going?
At around what speed are ya'll hitting 2,000 rpm's. My friend has a 99 1500 Z71 nbs that I think has 4.10 and he hits 2 grand at around 65. His dad has an '02 z71 and I think he has 3.73 and he hits 2 grand a little after 65. Well on my truck I hit 2 grand a little after the speed that he does So I was thinking that I had 3.42's. But my boss just got an 05 z71 cc and he hits 2 grand at a later mph than I do. To say the least I'm a little confused. (Me too buddy :cheers: ) Could somebody shed some light on this.
Why don't you just check your glovebox codes?
GT4: 3.73:1 Rear Axle Ratio
GT5: 4.10:1 Rear Axle Ratio
GU4: 3.08:1 Rear Axle Ratio
GU6: 3.42:1 Rear Axle Ratio
i gots 3.73 and 0.8 overdrive(i think) and 2k is about 68mph
You have a 0.696:1 Overdrive.
MudBug,
There is a 90% chance your boss has 3.23's since he has an '05 model. You probably have 3.42's.
or..if you wanna check your gear ratio and don't have means to check the RPO codes plug in this simple forumla.
Gear Ratio = RPM x Tire Diameter\MPH x 336
:cheers:
:crackup:
:cheers: My gear ratio is 45,360,000 :crackup:
Yeah...I failed Match.
:crackup:
No you did it right... the formula is wrong.
Should be:
Ratio = (RPM x Tire Diameter)/MPH x 336
Order of operations is important :crackup:
and that's assuming a 1:1 ratio in the transmission, which isn't true with an overdrive trans in 4th.
Yeah...Um...I failed Math.
Come to think of it...I'm 33 and I've never been married, so I guess I'm failing at "Match" as well.
:crackup:
Should be:
haha sorry about the order of operations. I actually got the formula from a book "Auto Math" by John Lawlor, its pretty cool.
