power window lock
I've go a 01 Sierra xcab that I put a Denali driver window switch in. The Denali switch has the window lock, but is definately not plug n play with my 2 door. Is there any way I can make it work so my dog will quit rolling her head up in the window......
Not sure if this will work but you could wire it like a disconect switch, where when it is pushed in it cuts the power to the switch,
And I bet your dog knows what she it's doing, "laughing" at your reaction when she does it.
On the 99-02 trucks each window is operated by its own switch, the driver's side only sends a signal to the other side to go up or down.
This is different than the OBS trucks where the driver's side fed both sides power.
Because of this you will have to do some wiring on both sides.
You need to wire a relay to cut off the power to the passenger side when the lock out switch is engaged.
If you need help doing this PM and I'll help you out. Gotta go right now.
Later.
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
