Once again, NOW I've seen it all
OnBelay
I can't believe I looked, but I found one auction where somebody actually bought one of these:
Click Here.
So not only is it incredible that somebody is selling this pitiful concept, there is actually somebody else out there that wants one!
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 594 Guests (See full list)
