4L80E Shifting Problems
Desert Rider
I have a
1993 3500 Dually with 454 TBI and the 4L80E transmision (150k mi on original trans, worked great till now), I tow a 30 ft Toy Hauler that is 8700lb dry.
I have already serviced and replaced the 1-2 and 2-3 shift solenoids.
My problems are
1 When I pull away from a stop the trans will stay in what seams like 2nd gear accept no engine breaking. if I select 2nd gear it has engine breaking so I am not sure that it is realy in 2nd. This kind of comes and goes.
2 When I am in OD at speed in 4th gear it will gust drop into 3rd gear and will not go back into 4th gear unless I stop and restart the truck.
Thanks
Scott
Hi everyone,
Just thought I would that I resolved the problem.
The insolation on wires to the forward speed sensor had been damaged from a small leak from the speed sensor and where shorted together.
And still no code!!!
Either way I am back on the road with all 4 gears
Desert Rider
