program code reader
phonedrn8
how far can a code scanner go into history? i have a brake light and ABS light problem happens when it wants to . dealewrship says bring in Monday night get to it Tues.. Want to go get a OBD2 scanner are they worth it? and how much should i spend around 150.00
Depends. There are a variety of factors, but most DTC's will remain in history for 40-50 drive cycles where the DTC test has run AND passed. In other words, just turning the key on and off 50 (or even 100) times won't clear it. The conditions have to be met for the particular module to say, "Okay, I've run the test and it passed" and do that 40-50 times. The light itself may turn off immediately when the problem doesn't exist, or it may require 2-3 drive cycles where the DTC passes before the light goes off... but the DTC will still be in history. This all depends on the module in which the DTC is set, but primarily the PCM is the one that will keep the light on even after the problem is fixed. You have to either clear it with a scanner or it has to go through those required drive cycles before the light will go off.
There's often some freeze frame data or failure records that will tell you under what conditions the DTC set, how many miles ago, etc., etc.
I can't comment on the aftermarket code scanners. Don't know anything about them. The one we use in the dealership is the best of course, but at $2300.00, just a bit beyond the average do-it-yourselfer's budget. Heck, I have a hard time getting our dealership to buy an extra one at that price. We have two and could use one or two more.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
