FSTDL Posted September 28, 2005 Posted September 28, 2005 Between a 4L60/65 and the 4L70 that is in the Vortec Max and what eles have they put this in. Thanks for any info Phil
GM-Tech Posted September 28, 2005 Posted September 28, 2005 Between a 4L60/65 and the 4L70 that is in the Vortec Max and what eles have they put this in.Thanks for any info Phil <{POST_SNAPBACK}> Guess I must be behind in the times. I never heard of a 4L70.
FSTDL Posted September 28, 2005 Author Posted September 28, 2005 It the trans they put in the Vortec Max Heavy duty towing package.I never herd of it either until the V/M came out.But I have one on order and was looking for some info. It also has a 9.5 inch rear end. Thanks
drumset5994 Posted September 28, 2005 Posted September 28, 2005 Between a 4L60/65 and the 4L70 that is in the Vortec Max and what eles have they put this in.Thanks for any info Phil <{POST_SNAPBACK}> Guess I must be behind in the times. I never heard of a 4L70. <{POST_SNAPBACK}> I'm way behind the times...imagine the laughter when i went in looking to buy a 2006 Chevy S10. Sorry to post whore...continue...
GM-Tech Posted September 28, 2005 Posted September 28, 2005 It the trans they put in the Vortec Max Boy, I'm really feeling stupid today. Never heard of a Vortec Max either. What kind of vehicle is this in?
budhayes3 Posted September 28, 2005 Posted September 28, 2005 It the trans they put in the Vortec Max Boy, I'm really feeling stupid today. Never heard of a Vortec Max either. What kind of vehicle is this in? <{POST_SNAPBACK}> It's new for 06...I think it's available on certain extra cabs and crew cabs, but not regular cabs . The package consists of a 6.0, 4L70E trans, and 9.5" rear
FSTDL Posted September 28, 2005 Author Posted September 28, 2005 Its the HO 6.0 and hope mine gets here soon!
budhayes3 Posted September 28, 2005 Posted September 28, 2005 A few links: http://www.chevrolet.com/pop/silverado/vortec_max_en.jsp http://www.chevrolet.com/silverado/features/
GM-Tech Posted September 28, 2005 Posted September 28, 2005 Well, whaddya know. We usually don't find out about new products, features, etc., until there's one in for service and we have to learn real quick.
GM-Tech Posted October 12, 2005 Posted October 12, 2005 Here's the info I got on this today. It's brief, but it's a start. Sorry about the formatting, but that's just the way tables cut/paste over. Pictures are lost too. ----------------------- Info - New Product Announcement - 4L70-E (M70) Automatic Transmission #05-07-30-026 - (Oct 7, 2005) 2006 Chevrolet Silverado, TrailBlazer SS 2006 GMC Sierra with 4L70-E Automatic Transmission (RPO M70) General Motors Powertrain required a version of a current production rear wheel drive transmission capable of handling higher torque and horsepower without going to a larger size transmission. As a result, the 4L70-E was created. Very much like the 4L65-E, the 4L70-E shares many of the same components and adding premium materials and additional manufacturing processes, the 4L70-E is capable of handling up to 400 horsepower and 430 foot-pounds of torque. It is also capable of increasing shift speeds up to 6000 rpm. The 4L70-E will be first introduced in some 2006 mid-size sport utilities and full-size pickups. The 4L70-E will be identified as RPO M70. The M70 will use the large 300 mm (101K or 112K) torque converter. Some M70 models will be the first 4L60 series transmissions to receive the new input speed sensor (ISS) . Below are the 2006 4L70-E applications and models: • Sport Utility 4L70-E models with ISS: SKD/TKD • Full-Size Pickup 4L70-E models: CMD, CWD & KMD Important: The following graphic and table describe only the essential components that make up the M70 transmission model and will not identify all parts. The following identifies the 4L70-E (M70) components and the components it shares with the 4L65-E (M32) transmission. Item Number Part Description ID Feature RPO M32 RPO M70 1 300 mm/112K Torque converter (1) • Identification code label affixed to the convert cover • Outer diameter & lug size X X 2 5-Pinion input carrier Asm. (662) Number of pinion gears X X 3 7-Plate 3-4 Clutch Asm. (7 friction, 6 steel plates) • Number of friction plates • Steel & apply plates have "HD" stamp • Friction plates have Identification stripe X X 4 5-Pinion Reaction Carrier Asm. (681) Number of pinion gears X X 5 Reaction Internal Gear Asm. (684) 3 machined grooves X 6 Output Shaft (687) One identification band X 7 HD Low and Reverse Roller Clutch Asm. Bronze clad cage X X 8 Input Sun Gear and Forward Sprag Asm (642) Paint marking X X 9 Input Turbine Shaft One identification band X X 10 Stator Shaft Darken splines X X Refer to the appropriate SI section for additional repair, diagnosis or description information. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION © Copyright General Motors Corporation. All Rights Reserved.
