air cond
have a 02 2500 hd air has bin worked on 4 or 5 times know its there again for air cond again dealer called and said there is r 12 in system and they dont know what they are going to do . they are the only ones who has worked on truck i have a gmpp extended warranty is dealer trying not to fix air cond right. so since i have a gmpp why would i mess with it they said i paid someone to work on it and they put the wrong stuff in
tell them to prove there is r12,... isnt the old stuff r22 anyways, and it runs on r134, ask them for a lab test or go to a different dealer
That's easy enough. The AC recovery machine ALL GM dealers have is an ACR 2000, with a refrigerant identifier built in. That's how they know there's R12 in the system. When you go to recover, it first tests the refrigerant so it doesn't contaminate the machine. It will then tell you if there's R12 in the system and at that point, it will refuse to remove the freon from the vehicle.
On the other hand, the identifier in the ACR 2000 has been known to go bad and say there's R12 when there really isn't. We've already had ours repaired once for this condition.
THATS TURE IF IF THAT SHOP IS USEING THAT MACHINE, BUT IF IT IS TURE AND DOES HAVE R12 HOW IN THE WORLD COULD ANY SCREW THAT UP
If it's a GMPP or a warranty repair, they have to use that machine because when all is said and done, it spits out a repair code that has to be submitted along with the repair.
just talked to dealer now they telling me it could lubricant that they use for system and that mite have made the r 12 code kick on true or not. and wheel speed sensors are bad and it will take 5 days to get new ones in
No matter what there machine says is in the system the truck was originally charged with R134a refrigerant. If the A/C is not working there are ways to diagnose if the system has the wrong refrigerant(this is not likely). Sometimes the automotive A/C techs tend to rely on some of these machines to troubleshoot for them. What are the problems with the A/C? My day job is commercial A/C and refrigeration.
