Autoride
RichJ
Hi guys.
Iam having problem with AUTORIDE feature.My compresor does not pump air.
I have overloaded my trailer one day and since than,my compresor is not working.
Message center is OK.Manual does not give me any help.(fuse OK)
Any advise?? RICH
Are there any DTCs? These are not simple systems. If you don't have the equipment or information to diagnose it, guessing at something won't get you very far... or can cost you a ton of money to throw parts at it.
  • 1 year later...
I have the opposite problem. My 05 tahoe LT with autoride is riding higher than normal, and of course much stiffer. My dealer had the vehicle for 2 days and said they dont have much experience with autoride and would get back to me. I take that as your on your own. You would think they would have a direct line to GM. Has anyone else had this issue? No codes were seen by the tech, and nothing showing on the dash. I think all they did was left the battery unplugged for the 2 days to see if it would reset :chevrolet:
Last time my compressor stopped working the dealer had to replace it under warranty. But I don't even tow anything - it just decided to not work anymore.
I own a 2003 Yukon Denali. The autoride pump does not start when I put my race car trailer on it. The back of the truck drops about 3 inches. I have 22 inch rims and a good size tire on it and this causes the tires to rub the inner well when loaded. Please help as I cannot find any info on the system. I would like to try and fix the problem myself and save a few bucks.
Thanks
Kevin from Canada
