2005 GMC/Chevy Stereo Swap
Hello all. I just replaced 2005 :D Sierra 1500 Single CD with 'brand new' 2005 Avalanche 6 Disk Head Unit. I have all functionality except for "CAL ERR" at start up and the button back lights never not turn on.
Had a buddy at a non-dealer repair shop and old software (up to 2003) try his Tek2, but he only got as far as replacing the VIN in the Av radio with my vin.
What else is needed to take my original RPO of UB0 up to the to 6 CD RPO of UC6?
I would like to approach the dealer with explicit instructions if available, since their typical response has been: Ask service, they say check with parts, parts says "don't think you can do that, check with service", etc etc :crazy: .
Please help before my head spins off at the dealer! :chevy:
The dealer should be able to simply retrieve the info from the old radio with the Tech 2, take the Tech 2 to TIS 2000, select "Replace & Reprogam Module", select Radio, then select the various speaker/equalizer options you have and download the calibration to the Tech 2. Then take the Tech 2 to the vehicle, select service programming and then program module.
Sometimes, you need to know the part numbers, so if you can get the part number off the 6 CD radio you put in before you go to the dealer, that might help to speed things up if it's needed.
Specific enough? :chevy:
Thanks GM-Tech!
I have to apolgize because this...
"The dealer should be able to simply retrieve the info from the old radio"
Should have said this...
"The dealer should be able to simply retrieve the info from the NEW radio"
One retrieves the info from the module one is going to program, not from the module being replaced.
Ok, GM-Tech, I'm trying to do something similar to my future son in law's 2004 2500 regular cab PU. It has the bottom end AM-FM radio in it, and I've got my old 6 disc changer out of my 2004 Silverado SS with Bose. I plug the 6 disc radio in on his truck, do the theft-lock bypass trick, and the radio plays, no problem except it has low volume. Can this head unit be programmed to his truck, or do we need a different head unit.
Thanks in advance.
They are, as far as the radio is concerned, the same year/type vehicle, so I see no reason why it wouldn't work. I assume you also put in the bose amplifier along with the radio?
What is the "theft-lock bypass trick"??
No, I just plugged the radio in.
Theftlock by pass trick--plug radio in, start the truck, theft lock is displayed, turn ignition to accessory position, unplug radio, plug it back in, and it works. This is only useful for testing, as the next key cycle it goes back to locked.
I learned this useful little trick on the Chevy Avalanche forum when I changed out the six disc and put in the navigation head unit.
Do the regular cab trucks come with Bose? Do they make a CD player that is not Bose? Where would one find this unit. My Chevy parts guy says he can't differentiate between Bose and non-Bose in his catalogs. Will this head unit not work without installing a Bose amp? I know that in the extended cab trucks the Bose amp is under the console, but I've never heard of anyone putting one in a regular cab truck.
Thanks for your help.
  • 1 month later...
GM-Tech..... just found this thread so I'll ask another question concerning factory radios. Will a factory GM radio / CD with MP3 work in a 2005 GMC with the "standard" factory CD player? I did not know that GM offered a MP3 receiver until we got in a new Colorado at work that has it. What models / years is this being offered and would a MP3 receiver from a Colorado work in a GMC Sierra?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
